It is currently Wed Jun 25, 2025 11:13 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 31, 2006 6:19 am
Paul, What are the dimensions of these linings? I assume the total thickness is .25" as you said earlier. How wide are they? It seems that you would have to be very careful to glue them in at a flat plane before sanding the top or back radius due to the stiffness, so they would end up being thicker towards the butt end than at the neck is that right?
Have you ever considered making them two toned from different colored wood?John How38868.6394907407
PostPosted: Wed May 31, 2006 6:32 am
John, right you are. They are 1" tall and .25" thick. There is a good deal more sanded from the upper bouts than the waist area. So the top of the linings are straight and the bottoms are profiled.
Yes, I've done two tone. I did spruce with mahogany caps. I wasn't totally nuts about the look though.
PostPosted: Wed May 31, 2006 6:53 am
$36 per set. Sounds great. I'd like mine to be Brazilian Rosewood.
PostPosted: Thu Jun 01, 2006 4:23 am
So.... is this a big enough order for you to cook up a batch of these Paul?
PostPosted: Thu Jun 01, 2006 4:25 am
One guitar, Paul. Sorry for the confusion.
